My 86 Fummins Project
Matt_P
Lima, OH
I forgot how much fun it is to sit down and try to design a fuel system on jegs till I saw that lol
haha oh yeah its always fun trying to piece it all together in your head.
Now the fun of putting all the hoses together. I hate that part.
Sent from my shoe phone
I wont mind that part as much now that finding every fitting I need is over with!
Awesome Matt!
Thanks Steve!
Get a little bit of penetrating oil and fine grit sand paper and get rid of that rust!
Oh I will for sure, I still need to get a new governor housing gasket so Ill get that cleaned up before its bolted back together
jdc753
Norton, MA
Thank you!
Its gonna be two tone now, still gonna be tuxedo black metallic on top then dark charcoal grey metallic in the center and tuxedo black metallic on the bottom
That is going to be flat out gorgeous!! Modernized version of what my dad's work trucks have always been, black/silver 2-tone, even ended up adding it to his super duty in the classic 2-tone like you described not the simple bottom strip style.
Matt_P
Lima, OH
Thanks Josh! Im really exciting for when the body work is going to start. Ive always loved dark grey on trucks, but I didnt want to do the whole truck that color so I figured why not combine the two and do a nice two tone like all those trucks normally had. Im hoping it will all turn out the way I have it pictured in my head
Got some more work done today.
Built the mount for my fuel system out of 1/4" aluminum, it will be polished. Im still waiting on one filter base to show up so that kind of has me held up at the moment. But I have that mounted and the -10 line made from the sump to the water seperator. Im gonna wait to make the rest of the supply line and return lines once the cab is on next week. I also built the oil supply lines for the vacuum pump and p pump
Matt_P
Lima, OH
Thanks!
I got the last couple fittings I need today for the fuel system. My other filter base is still MIA with ups. My 5x.012 injectors should be here tomorrow and as soon as I hear back Ill have my S363/68/.91 on the way
slc dzl
Riverton, Utah
That pump filter setup looks great and is clean, may have to redo mine to something similar.
love this obs project btw :thumbup:
Matt_P
Lima, OH
Thank you! Im really happy with the way the mount came out, itll look even better when its polished up
TrailerHauler
Michigan
Thanks!
Who are you dealing with for injectors and pump work? I need to get the injectors in my 12v checked out and probably have the popoff reset. Not sure who I should go with.
Matt_P
Lima, OH
I bought the injectors off a guy from comp d as well as the pump and I tore the governor housing apart, modded the afc, delivery valves etc. myself. When i had a broken governor weight on the pump on my king ranch Columbus Diesel Supply fixed that and flowed it and they rebuilt my injectors. They did a good job but it took a while.
Matt_P
Lima, OH
Made some good progress today:
Got the truck back on 4 tires
Then Rolled it outside
Grabbed the 150 frame and brought it inside
Cab ready to pull
Cab off
Cab on the 350 frame
Plenty of firewall clearance
Got a little more done on the fuel system, now that the cab is on I can finish the plumbing and get the holes drilled for the filter bases on the mount
Pulled out the heater box, since Im gonna run one with no AC so it will look a little cleaner and Ill have better clearance for the turbo since I dont want to use the industrial manifold I have
Also got my driveshafts back today
Matt_P
Lima, OH
Super clean man! What are you using to cover up the heater box hole?
Sent from my Pear phone 5 using Tapatalk
Thanks! Ill still have a heater box going back in just one with no a/c
Little more progress.
Cab pretty much completely stripped
7.3 powerstroke brake booster and master cylinder installed for mockup with new stainless steel brake lines. Just need to modify the lines for the rear brakes to attach to the manual adjusting proportioning valve
Powersteering lines done:
Mock up for top heater hose
Core support on:
All new chrome for the front with the custom billet badge
