My 6.0L 700HP Build
Boostaddict03
Our Mods are below
Compound Setup S480 and S472
Warren Diesel 500/225s
Dual High Pressure Oil Pump Kit
Fuel Lab Fuel System
Headers and Up Pipes
O Ring Heads
Cut and Coated Pistons
Hypermax Rods
Sun Coast Transmission with a 2800 Stall Converter
Water Meth
3 Stage Nitrous System
The truck put down 705whp on Fuel on a Mustang Dyno and on a .093 Jet put down 810whp with just one stage. More numbers to come... with more tuning.
Boostaddict03
Went 7.8s on 35inch Tires with the Transmission not Shifting 1st to 2nd and
3rd to 4th at 93mph
Boostaddict03
Bring me a 6.0L or a 7.3L that will put down over 800whp on my Mustang Dyno ON FUEL my Dyno is a Low reading dyno Im looking at track times that is all I care about Brian with his 7.3L went 7.0x on Nitrous this weekend and apparently his truck makes 1000hp
Boostaddict03
The Injectors are flowing somewhere around 400cc's bout to upgrade the spool valves to get them up to 460cc
strokin6L
Springville NY
Warren made little over 700hp with a single S475 and a set of 350/100 cove nationals with his dual HPOP setup. Something just isn't adding up with your setup.
1fastTRX
93mph in the 1/8th sounds quick. I dont know what hp it equates to though.
Sent from my SCH-I535 using Tapatalk
