Steering box
GreenF350
Near Pensacola, FL
Nope. That little needle bearing can be replaced by itself. I can't remember if it was in the parts store catalog/computer or if I just gave them the number off the bearing when I replaced mine. Real cheap for the bearing.
-Aaron
DEEZUZ
NO PUKESTERS
NWI
Thanks.
Got er done tonight. I started to loosen the line from Hydro to box and it started to twist. Luckily parts store brought a line right over.
The drag link came off Ok, I left the nut on a bit and hit it pretty hard with a mini sledge, didn't budge. I put the puller on and when I tightened the arms down or dropped right out.
Pitman arm literally fell off with box on the bench. The splines were completely FUBAR.
With the new pitman I had to adjust the drag several turns. I went too far now and wheel is a rad to the left.
But this thing steers amazing now.
Dmstrucks02
Pearland, TX
Hopefully they dont deny you the core refund with splines messed up. Did you read the paperwork that came with it?
Sent from my SAMSUNG-SGH-I537 using Tapatalk
DEEZUZ
NO PUKESTERS
NWI
I think the shaft splines were ok, just pitman chewed up. I'll check when I get to work monday
And I didn't receive any paperwork with the box
DEEZUZ
NO PUKESTERS
NWI
Lol. You tell me man.... The output is fine, no marks at all...
GreenF350
Near Pensacola, FL
I've seen a realize that and they all had loose nuts. Not sure how it happens though. You'd think the edges would get tore up before the middle. The output shaft is a harder metal than the pitman arm that's why the shaft isn't damaged.
-Aaron
Dmstrucks02
Pearland, TX
Even with a loose nut. As hard as it is to get the pitman arm off I wouldn't think it would mess the splines up on either the shaft or the arm
DEEZUZ
NO PUKESTERS
NWI
Probably have 500 miles on since box change. Hands down money well spent. If you have any doubt, stop putting it off. Truck feels 100% tighter
edge186
SLC, UT
Used my truck last week to haul a gooseneck trailer and tractor and remembered how bad my steering was. Finally bit the bullet and ordered a gearbox this week. It came today. Can't wait to get it installed.
DEEZUZ
NO PUKESTERS
NWI
Like mentioned, order new lines as well. Chances are they are chauffed and or will twist when being removed.
edge186
SLC, UT
Did you order them from a dealer? What was the cost? Any chance you'd have part numbers?
Also, where did you get your new pitman arm?
edge186
SLC, UT
Installed the redhead today. Need to bleed the lines but the wheel will not turn. Any ideas?
