6.7 Twin Turbo Setup
4EverBoosted1
Also... I don't have the engine in front of me right now, where do you guys suggest tying into for oil pressure sensor?
I tied mine in right into the factory oil temperature sensor by the filter housing... Does that make sense?.. Here's a pic
Dan
Fort McMurray AB Canada
is the factory sensor gone?
Isn't it a pressure switch? No it's still there just putting an aftermarket one in to monitor pressure
Wow!! Thanks kaleb!! Appreciate it man! That'll work perfect!!
MorganY
college station, tx
Be warned.T'd into the temperature port will throw the oil temps way off. Put it on the opposite pressure side.
Sent from my SAMSUNG-SGH-I337 using Tapatalk
MorganY
college station, tx
Tying into the factory oil temp sending unit location for your additional pressure sensor will result in the factory temperature sensor reading out lower than being in its stock location.
Between the "T" used to tie into the system dissipating heat, and moving the factory temp sensor away from the direct flow of oil inside the filter housing, temps will read out lower. 20 degrees lower give or take a few degrees.
Dan
Ok yeah!!! Haha I follow that part!! I just don't follow what you are suggesting I do instead! Haha
Dan
Yep 10-4 sorry I don't have the engine right in front of me or pictures too look at! But hey thanks for that!! That totally makes sense! Thanks morgan
6.0L Stroker
Southern Illinois
Not to muck up your thread Dan but just thought I'd inform the guys that read this. I noticed my oil filter leaking the other day. Figured it was just a little bit loose. It was tight and I noticed the oil coming out of the seam of the filter at the top. I don't know if it's just a bad filter or what. Sad part is its only been on for 1000 miles. And it's the Motorcraft filter.
Sent from a lawn mower
Dan
Your all good! I noticed that it'll leak a bit but you tighten it down real tight and then wipe up the excess oil once and it does good after that... I might be way out too lunch too! Haha
In other news: switches!
I swear this is the cleanest I've seen this truck! Haha
Kinda
And here's our variation of what kaleb so kindly shared!
Also there's a bov controller in there somewhere!
dsberman94
Pennsylvania
Kinda
The switches are awesome. So awesome that I think I need a link to them. The exhaust coming out the side of the bed is awesome as well. First time I've seen this thread. Guess I'm gonna have to read back in here.
Crack85
Midland, Tx
The switches are definitely sweet. The truck will forever be dirty where the exhaust dumps through the bed.
