6.0.4 revisited
Would you put 6.4 compounds on your truck?
  • Hell Yeah!
    Votes: 33 30.6%
  • Sleep on it.
    Votes: 10 9.3%
  • Not going to waste my brain cells on this one.
    Votes: 24 22.2%
  • The juice isn't worth the sqeeze!
    Votes: 26 24.1%
  • My truck already has 6.4 compounds!
    Votes: 15 13.9%
  • Total voters
    108
TheReelMuhcoy
New Jersey
285/150 hybrid, don't pussy foot around
Ya, I'm not sure about that, I would like my pistons to remain in solid form. Glad I missed that derail.
I'm not sure how much fuel these turbo's are going to handle on the 6.0. I am thinking I may need to run stock sticks and push it as far as I can with just tuning, then upgrade based off how the stock sticks do. I would like to try to push 550Hp +/-, time will tell.
Dustball8504
Everett, PA
If you can get it to work it won't be a problem going 550. I personally think that you'll be tapped about 450-475 on stock sticks. Stock charger on the 6.0 already does a good job cleaning up stock injectors. I think you'll clean 190/75% up with these turbos.
alwil
Saskachetoon
Do you happen to know what 6.4 injectors flow?
windrunner408
I agree.
Pizza pig
MD
its irrelevant in this discussion, stock 6.4 nozzles flow from what i've been told 24lpm. But on what bench, how much pressure, what kind of fluid, what measurements, what pulse width, what rpm etc. The two entirely different injection systems are lightyears apart to even begin this discussion. I think the best match for smoke free, fun power are going to be a 190/75. Your horsepower goals will be reachable and will have great street-ability. Cant wait to see this thing start taking shape.
TheReelMuhcoy
New Jersey
Greg,
Are you trying to talk me out of your injectors? haha
I am thinking 190/100's and pull fuel in tuning if necessary, but doubtful. So the next thought is should I just run stock injectors, before upping them, to get an initial dyno# to see what just the turbo's alone do?
alwil
Saskachetoon
Yeah cause you would never think to maybe find out what a 6.4 injector flows and then try to match it with a 6.0 injector.
Instead people will just go with what you " think" instead of actual data.
windrunner408
Greg,
Just running the turbos with the stock injectors won't really give you the true performance potential that adding extra fuel for all the extra air will. It will be interesting to see for sure what they do but I think the stock injectors should be first utilized to make sure the turbos are working and functioning properly. I just wouldn't expect any huge gains. There of course should be some gain but not like what you would see with blending in the right amount of fuel for the extra air.
Pizza pig
MD
I think you're missing the point. You do know how different the common rail and HEUI injector is right? I think anyone who uses a flow bench will tell you the same thing. But I like your enthusiasm.
TheReelMuhcoy
New Jersey
There just is not enough data available to determine what sizes are comparable, I did some research and I couldn't find any volume ratings for 6.4 injectors only HP ratings. And even still I believe you guys are right, a 6.0 makse 60 psi of fuel and. 6.4 makes upwards of 26,000. Totally different fuel system to try to compare.
Pizza pig
MD
the 6.0 injector makes over 20,000 psi fuel pressure when the plunger is forced down to inject fuel by high pressure oil. Just in a different way.
Mdub707
Mohawk NY
Exactly. It's a 7:1 pressure ratio stock right, and figure 4000psi max out of a stock 05+ HPOP... 4000x7 = 28,000... or so.... That sound reasonable? Obviously there will be some parasitic losses through that. Or am I way off base here?
The fuel certainly isn't being squirted out at 60psi...
MorganY
college station, tx
You're correct, sir
TheReelMuhcoy
New Jersey
Yes I had a brain fart there. I was really just thinking of the fuel delivery to the injector there. Didn't think it all the way through. Either way there is nothing out there that compares volume of a 6.0 injector to a 6.4 injector, I'll have to see if I can get in touch with someone who works on both types of injectors.
SSpeeDEMONSS
6mi from the beach, SoCal
so an HEUI sytem, on an 05+ 6.0 at 100%, injects fuel at 28,000psi? then why is injection pressure always brought up when talking about HEUI systems. doesn't sound right to me.
Garrett
Pizza pig
MD
Garrett
The more fuel capacity thats in the barrel, the more volume of oil that is needed to empty the barrel depending on the nozzle. This is why larger capacity, 225s for example with a 100% nozzle has trouble holding icp pressure because the stock pump cant supply the volume of high pressure oil needed to empty the barrel at a certain pulse width
Hopefully that answers your question?
TheReelMuhcoy
New Jersey
What I really want to know is, what are we referring to when we say a "190cc" injector... It can't be 190CC per injection, my guess is 190CC per minute, but then I wonder at what RPM...
This is above me......
