6.0.4 revisited
Would you put 6.4 compounds on your truck?
  • Hell Yeah!
    Votes: 33 30.6%
  • Sleep on it.
    Votes: 10 9.3%
  • Not going to waste my brain cells on this one.
    Votes: 24 22.2%
  • The juice isn't worth the sqeeze!
    Votes: 26 24.1%
  • My truck already has 6.4 compounds!
    Votes: 15 13.9%
  • Total voters
    108
TheReelMuhcoy
New Jersey
May need to move ficm. I have not yet gotten to that point. If necessary I will due so by purchasing pigtail connectors and splicing and moving it only as far as necessary. Same goes with the coolant bottle. From looking at it as I have, it will all be very close, but it is hard to tell untill things start going together.
MorganY
college station, tx
Thats the best way to find out, good luck with it Jon.
TheReelMuhcoy
New Jersey
Thanks Morgan.
I should mention that I am at the point now where I am ready to start the build as far as parts are concerned. I am holding out for a few reasons though 1) I am still working on the actuation electronics 2) I am busier than hell with work and need my wheels 3) my buddy's shop where this will likely all be done is a bit cluttered right now while he finishes putting together my business partners jeep and does his HG's on his truck.
Meniacal_Mark
I don't know if anyone has posted this yet but, the name of the engine Cutting-Edge was talking about is the Maxxforce 6.0D
F-250-Owner
Masontown Pa/Maputo Mozambique
If u have to move the ficm.... I have several e series harnesses available... they have the ficm on the fender well...I also have the bracket...pm me if intetested
Sent from my SPH-L710 using Tapatalk 2
fordfreak4life
Interested
Sent from my Milestone X2 using Tapatalk 2
TooMuch03
West Bend, WI
Doesn't the E-series incorporate the FICM harness into the engine harness, instead of separate like our trucks do?
F-250-Owner
I am going to seperate the ficm harness out of the main harness.... it will make it alot easier to adapt to the F series engines.... The E series engines all have alot of extra accesseries that the F series doesnt have.... this is the best way to make the Ficm relocation work using the E series harness....
Mdub707
Mohawk NY
I'm not positive, so take this with a grain of salt... but didn't BPD look at possibly moving the FICM before they came out with their new design... does anyone remember why they opted NOT to do that? I thought I had read they were concerned with a few things extending the harness and moving the FICM from it's current location? Anyone recall anything on that?
TooMuch03
West Bend, WI
IIRC, the reason they opted not to move the FICm was because that does not actually fix the issues with the FICM. Heat and Vibration are only a small part of the reason the FICMs fail.
F-250-Owner
alot of the interest I have recieved about the harnessess is due to wanting to add turbos and moving the ficm just for that reason... my harnessess will come with the E-series FICM mount as well.... they look like an envelope and mount over on the drivers side fender....
TheReelMuhcoy
New Jersey
SAEBEE,
Yes I will be fabricating a pedestal for the turbo's.
If the E series setup its as easy as soldiering all the wires in, then I will likely be doing this just to neaten things up in the engine bay.
Mdub707
Mohawk NY
Makes sense...
Any pictures of such a setup installed? With the amount of FICM's I swap in and out, it may be worth my trouble anyways...
