Rene G
- Joined
- Dec 3, 2011
- Messages
- 435
- Reaction score
- 0
I've seen 50-52, no studs, no puking.
lol, that turtle is a beast
I'm running the elite tow power atmo charger with stock head bolts. No problems, yet.
And I still have the factory ford fluid in the trans.... 115 k and counting.... In the next 5 i am gonna change it, and put a TC in it.... But i do like that it is still getting it with the Spartan 250 EL loaded in it, and hurts little cars with fart mufflers feelings.... LOL
might as well throw trips in while you are at it lol.
holy crap......that turned out NICE!
I saw 52 on stock studs. no puking.
Eric@HolderdownPerformance
Ok this maybe for the performance section, but I'm about to go through with no limits piping and mouth piece, and diamond eye 4" down pipe. This including Doin an egr delete. I don't have the funds to do a wastegated setup, so my question is will I be ok running the hotter tunes with it blocked off for now? I'm gonna go through KEM for the h&s sd card for my xrt.
Kudos to who started this!
If you're asking if the EGR block off will increase your chance of popping a HG, I would say no. Most (if not all) hot programs disable the EGR (if it is still present) during conditions where you run the risk of popping one...WOT, high boost, high EBP. I would closely monitor boost, EBP, and EGTs when running hotter programs. Not sure which year or job your truck is, but if it is Job 1 or 2, I would definitely start saving for studs or try to stay out of skinny (the temptation once you run the hotter programs is pretty tough!!!) no matter what programming you chose. I am not saying if you have Job 3 or newer you won't blow a HG, but they seem to hold a little better than the earlier builds.
How do you unplug the injector from the harness? I don't want to mess any expensive connectors up or something.
if you're going to spend the money on turbos dont' skimp on the wastegate, it will probably end up saving your turbos...
Does a 5" exhaust make any improvements in performance when you only run a intake and tuner? I have an S&B intake, H&S mini Max with KEM tunes and a DPF/DOC delete pipe. I plan no other mods except exhaust. Would I see any benefit going with a 5' vs. a 4" kit?
I didn't know they put studs in from the factory...
There wouldn't be a performance gain..only a change in the sound of the exhaust
