Jhaddox
So no harness at all? I'm thinking the same as you since mine is a manual since its flashed to be a manual, the 4r would be controlled by the PCS. Are you still suing the 5r flex plate?
Still use the 5r flexplate...you have to use the modular 4r case out of a v10 truck to make it bolt up though
You don't need the 5r or 4r harness. PCS has their own.
Whs 4r has their own harness...connect a few wires for inputs to the pcs and then tune it
