Dan
For engineers also designed the connecting rods in this engine....
Works good at stock hp levels...
Lmao. If Ford wanted the engine to run at 197° I bet you a million bucks this engine would run at that temperature. Contrary to popular belief, people that build these trucks are smarter than 99% of us and 2 people don't build one over the course of a couple months. So there is probably a reason why they run at 250° bone stock and didn't "opt for lower oil temps". But hey someone's gotta be the Pioneer right?
Ok ya caught me 97 strokes 350 I'll be the dumbass over here pushing the limits...
I'm taking my 150000 lbs across but first I'm gonna install and an aux oil cooler on my bridge
Not trying to be the asshole here but you and a few others keep saying your pushing the limits. I beg to differ, MPD truck and Caleb's truck are pushing the limits of the 6.7...hell even mikes truck in the making is more useful. You don't collect data and you break ****. Not sure which limits your pushing here. What did we learn from your CFD build or your CA build.
Here's a pretty good explanation of viscosity as there was misleading info earlier.
http://www.upmpg.com/tech_articles/motoroil_viscosity/
We also need to keep in mind oil gets thinner as it gets hotter. The thinner it is, the easier it flows out of bearing surfaces, and the less ability it has to protect and maintain adequate pressure. This is especially important where the engine is being taken beyond it's original design limits. Last round the truck didn't get the bugs all worked out before it was stressed to the point of failure. A known problem at the time was excessive oil temps, so he is having changes made to keep it in check. There is no finger pointing going on here, just soving a known problem. If everybody had more time to dial in the truck before dpc, all that stuff would have been addressed previously, but they ran out of time.
Considering the oil is cooled by engine coolant, we can easily see the target oil temp is also the target coolant temp, controlled by the primary cooling system thermostats. When the engine goes back in the truck, the plan is to add an oil to air heat exchanger with a mechanical bypass until it meets a minimum temperature. It will also have a thermostatically controlled fan to make sure it stays in a target range.
I really don't get why you guys are mocking him for upgrading an insufficient oil cooler. It's not like he's shooting for a temp range out of the ordinary here. Back when I did a lot of heavy towing with my built motor 6.4, my primary concern was excessive oil temp, followed closely by coolant. This was with a new, clean factory oil cooler. Pyro was a distant 3rd for temp concerns, and I towed in the race tune. Granted, I'm not complaining because I was flying past people who were maxed out, and I had way more weight. It was nearly perfect for what I wanted. That's what this is all about; a guy setting up his truck the way he wants, for how he intends to use it. Personally I think the oil cooler deal is a great upgrade. I look forward to seeing everything come together the way Dan wants it under less rushed circumstances.
So let's say you run "grocery getter" 5w-40 and you have an external oil cooler that keeps temps around 190-210.. Is that causing damage? I don't see how those temps could be doing damage but I'm not educated in the subject.
For a dedicated drag truck your best off with a 0w-30. With a optimum oil cooler. Full synthetic.
Thick oil provides much less protection in high speed moving parts than thin oil. Thin oil is leaving the designed space between the bearing and journal with enough room to allow the nicely heated oil molecules to roll properly.
Haha I would venture to say the rules are different when you make 6000 hp and rebuild your engine every other run
Not calling you out here, I am not equipped to do so. These statements go against what my understanding was for high HP engines. I've built some race engines, (gas), in the past and an engine builder explained to me the function of the oil between the crank and rod bearings was not only to lubricate but to resist being squished out under high load causing a metal on metal situation. It was stated thicker oils provide better protection through greater resistance to compression.
I'm pretty sure I saw a top fuel team using straight 70W. Probably apples and oranges though. Maybe you could provide comment on this?
