Trying to get back on track from cry baby town, what's the highest rwhp anyone has seen a 300/200 make on fuel?
What's the highest rwhp 7.3 anyone has seen on fuel?
Over 700 brother. Thuggy did 700+ on 250/200...and a gt42r
To answer one of the OP questions, i have towed with an S476 300/200 combination.
Is it for everyone? No, and I will tell you no every time.
Can it be done with out melting down the engine? Yes but you sure as hell are not going to be towing 15K in OD at 1800 RPM.
Good luck on your build.
Without pulling the thread, it was over 800 fwhp fuel only and 1000+ on moderate spray, never had it on a chassis dyno, only engine, so no 'official' rwhp numbers. It's been a couple years since any significant changes to that setup.
2 stages of progressive spray and didn't go above .120 jets, usually kept both under 100 to keep carnage to a minimum.
you can and it has been done.. but you have to actually drive the truck not just put it in overdrive and not pay attention. gotta keep rpm up so airflow is key..Just curious but why can't you tow heavy with a s4/6 300/200 setup like that? Is it more or less just for performance and not towing?
Even if you could make 700 on fuel with a 250cc injector why would you over having more capacity. A large capacity built into an injector can effect refill time. Again it is part theory kicking around but pushing an injector to completely empty a barrel of fuel vs having a good buffer built in sounds like having that buffer will be more efficient when the barrel is refilling. If your thinking of a 250/200 over a 300/200 which both have the same nozzle its not going to have any streetable advantage as to running a 250 over 300 or even 400/200
Two cylinder head men to consider is Eddie Ingrahm and Robbie Crutchfield.. Cylinder head work is pricey.. Depending how deep you go, Ferrera valves, custom springs and roller tip rockers just for 160/100s is a bit dumb.. Now for 300-450 cc injector that's where head work shines. Then we can talk about cam shaft development.. Not to mention how much faster injectors have gotten and break throughs on IDMs due to swamps development... Spend say 12k total to make 500hp with said 175/100 injector, or drop a set of 238/100s in with spring, p.r's and arps with todays GT38rs.. Shoot 500 is cake with good tunes. Obs guys have to change a few things and add a cooler but that's just part of it.. I think the o.ps goa of 700 is soo doable and happy to see some people still throwing time at the old dinosaur. Great work man!
Matt fogged the living snot out of it on the dyno. 300/200's are typically a solid 650-under 700hp injector. Fuel only, he never hit above 700.300/200 are an 800hp injector. Matt made over 1200 with 350/200 on the dyno. Yes he fogged the motor but the fuel potential is there. You may not hit 800 on fuel with those injectors unless you have a good set of compounds but a good flowing single and a small shot of nitrous and you will hit 800hp easily
Not on fuel only though. I chat with Scott on a regular basis.Clearly you don't get out much or keep up to date cause that number has been reached and surpassed. Zack pierce Brian jelich Scott Morris all have 7.3 that make over 1000. And there are others but that is just a few to name. You need to go back and do some reading. 7.3 aren't crappy hp makers anymore there has been new developments in fueling and tuning to make them true game players.
Not really, but the scary thing is I'm in management now lol.
You know why people like you move up into management so fast???? Lol.
Goal of work is to make money, not friends... As sad as that sounds.
Being fair, understanding and setting an example is the key to management. If I tell my guys we need to work all night, I'm right there with them turning a wrench. First one in and last one out, everyday. Phone turned on 24/7.... Living at work, it's great...
I only have 3 people here that hate me. Ones a democrat/socialist, other is fat/lazy and doesn't know how to use Microsoft office and the 3rd just bitches about not getting enough overtime but never wants to show up for overtime or can show up but can't work before or past X time... **** ain't gonna work bro lol.
On a side note, I did a test fit on my dads truck real quick today to get an idea.
Awesome!On a side note, I did a test fit on my dads truck real quick today to get an idea.
But yes, there have been some very nice improvements with the ole 7.3 in the past couple years. #beers
