72mm non VGT 300 150 dd setup
faster6.0
Yeah just for a second, possibly oot related.. Soon as it came out of the surge and spooled from 95-110 it Throws you back hard...50+ psi on mech gauge..then the boot splits down the middle. Sorry boot lol
faster6.0
YEEEE BUDDY! looks like she moves pretty good!
definitely man! cant wait to see your truck running just as strong! those compounds will be spot on. the tune being ran in the video was a year old tune from eric I had him write to attempt to maintain icp with 225 150s, so im betting there is icp and timing pulled pretty good... so hopefully there is more to it :)
SSpeeDEMONSS
6mi from the beach, SoCal
Sorry for the derail but on that cluster when the needle maxes out does it eventually swing back down to 0 or stayed pinned on the needle? If so, does it do so at 117? I know my 03 went from the 100 needle back to 0 at 107. Derail over.
Garrett
probably getting paid at work to post this from my bionic
faster6.0
Garrett
Stays pinned.
TooMuch03
West Bend, WI
Garrett
Hmm interesting question, I wonder what my 04 harley cluster will do...
:pullover:
faster6.0
Sounds like a runner, what wheel did they use in that turbo?
thanks man, It's Danville's compressor/machine Job that they do to the 4094va's that have made north of 800 on fuel. the non vgt unit has a sizable difference in turbine diameter (bigger) the turbine is a normal 4094r 77mm non vgt turbine.
windrunner408
There's no difference between the turbine wheel on a 4094VA and 4094R. They both measure out at ~77mm x 68mm for a trim of 78.
