Tim @ P.I.S.
Nice curves. Even with the tighter 1.0 housing. Looks like it pulls hard all the way through.
I dont recommend the turbo over 40psi. My current setup runs 36psi on an e99 setup with the 1.15 housing and larger e series turbine wheel.
The problem that occurs is the shaft can snap when you let out of a hard pull at 40psi or above. Also the thrust bearing, even though a 360 degree, can still fail if the boost/drive pressure ratio is past 1/1.1 boost to drive
Good to know.
What boost was used on that dyno plot to achieve the numbers posted?
Any clue what your test drive pressures were?
36psi boost, Still have to hook up a drive pressure gauge.
Lol, maybe i can get some dp readings this weekend.
