anyone see mpd's truck at rudys ?
WhiteMamba_Scorpion
Like I said... it's magic... Suncoast is wasting money selling anything 6R140 related since stock trans hold 2000+ ft lbs daily. I wanna see how many WOT passes it makes because this stock trans is a damn unicorn
bdm1981
Salem, Missouri
I call bs on the stock trans holding that much power. There is no way you would be able to drive it off the dyno let alone anywhere else for that matter if it made that kind of power. Good luck at the track cause if it is stock and still intact that will finish it off. Rant over...proceed fellas...:popcorn:
getstroked27
Friendship, MD
Shop just finished pulling the motor to put it in our UCC truck.... but regardless here is a time slip Craig just pulled out of the center console. Whenever any of you, including Morgan, want to play, just let us know. we will have one or multiple trucks ready to drag dat ass all over the track, dyno, wherever you feel safest homie.
Black AOD
Ohio
How much does it weigh? 8100?
Sent from my VS990 using Tapatalk
getstroked27
Friendship, MD
sorry, thought i had a better pic. this setup was running low 10's back in 2014 before they dropped the motor and turbo setup in the 15. so it has been doing this a while. just changing pumps tuning and built an air to air setup for it. truck weighed 6760. not to mention that was on fuel..... MFI truck never had spray on it.
getstroked27
Friendship, MD
funny how it got quiet when the proof came out..... Truck should be doing some pre UCC Shake down passes this coming week. should have even more on deck then. and again AT UCC. Then maybe if Y'all still want a show... we could make a date with Morgan on the drive back to hit up his local track....
bigrpowr
<How I Fly
Administrator
thats about what i figured mine would run. thats fast !calculator puts mine at 122mph . thats hauling ass, and crazy for a stock trans. mine was wasted at 700hp .
WhiteMamba_Scorpion
read it up... said MFI truck. how did we run a 10.17 in 2014 with a 2015 truck? lolz. this engine in our ext.cab truck. ran that on fuel. then pulled that and put it in the 2015. built new motor for race truck.
oh... so you post time slips and weight from A COMPLETELY DIFFERENT TRUCK than what we're talking about....
thank you for verifying that you're all full of bull****
getstroked27
Friendship, MD
nahh same motor and turbo. not gutted, clearly. at 6760. the 15 is just a 1600 hp plow truck.... not a race truck. its our UCC truck now.
