BIG BLACK is getting built!!!!
william_ace
^^ I hear what you are saying.
Next time I come to College Station, I'm going to have to meet up with you and check out your truck!
MorganY
college station, tx
Indeed. I make an attempt every time to warn those about to fall into the bandwagon, because I wish someone would have warned me back then.
Sure, give me a heads up and we'll get the group together, we do it more often than not now.
OP- I would recommend new Fords (Reman now) 205/100 from Elite or RCD. If you choose to have your injectors modified elsewhere, step down to a 190/100. My first set were Casserly @ Full Force. That was my injector combo that had the most value. Smoke free, stock oil system, plenty of extra power on tap, and an 18-month warranty that I never had to use.
Paris/Lebanon, TN
Lol noted!!! Just got off the phone with RCD and I'll be getting my sticks modified to 205/100's. Also ordering the FASS system and RR from them. They're getting a price quote for me on everything then I'll be sending my injectors within the next week or so. I appreciate the advise!
Paris/Lebanon, TN
You won't go wrong with RCD. Now is the time to do a manifold if you are that far into it!
It's probably going to happen lol. I'm just getting all the parts together and sent to the shop. My builder wants to wait until everything is there before he starts in on it. So i'll probably be giving you a shout in the nxt few weeks to scoop one of those up off of you. I'm also already looking at upgrading to the 68mm from RCD by the end of December lol. I think this is going to turn out as a solid build.
Powerstroked162
On Da Juice
Wa. State
I concur, I will probably have stock built up by then so downtime will be nonexistent. What's your trans situation? Built or stocker on borrowed time?
Paris/Lebanon, TN
So this weekend the injectors will be pulled and sent to RCD for the 205/100 modification. Monday i'll be ordering the 200GPH Flow Rate 50psi Titanium Series fuel system, Driven Diesel RR system, RCD billet input shaft and the Suncoast Iron-Pac 3 rebuild kit. Then on the 16th of next month ordering the Suncoast TC, Banks Techni-cooler intercooler system and hitting up one of those APEX manifolds. Everything should be on and ready for my return home from Iraq in December. Big shout goes to my friend Justin Binkley for doing this build for me while i'm gone. Hoping for a great reliable setup with some solid numbers.... Lol also already talking about upgrading to a RCD modified 68 VGT with the new billet wheel they're coming out with. Still open for suggestions guys! I've had a lot of great info passed my way and want them to keep coming.
Paris/Lebanon, TN
I'm wondering the same thing! Are you for sure going with the 205/100s?[/QUOTE
Yeah it's pretty much set in stone with the 205's. Elite told me even the SSX will clean the 205's.... if they don't then i'll pull a little fuel but main reason i'm going with 205's is because i'm eventually going to run RCD's 68. So it would be stupid for me not to just go ahead and get 205's.
Paris/Lebanon, TN
All parts with the exception of my APEX manifold and 205's were ordered today and headed to the shop. Already have a person interested in the SSX so if I can get it worked out then I might be rockin a RCD 68 instead.
