Black Magnum 2.0 assembly
Magnum PD
VA
The guy I gave the plans to hasn’t got started on it yet. He’s been busy. There are other places that it can be done at.
Magnum PD
VA
Afraid not. I took precision machining during high school but, don’t own one.
ja_cain
Sounds like you need to buy one so you can utilize that education! Use it or loose it. Or, you could always employ Shannon to make you one. Lol!
njjeep
Brick, NJ
What about just getting weld on aluminum fittings and use JIC fittings
I’m sure if they are tig welded on they will be strong enough
Magnum PD
VA
I modified my IPR a second time, still going down to 3.1% but not throwing a CEL yet. See what happens.
Magnum PD
VA
Is it worth while to try and put on a used 15* pump I got to see if that will bring the duty cycle up? To refresh, dyno proven tunes I had did the same as the G head tunes I got now. Only throws the cel when I’m keeping the pedal steady and not wanting anymore gas.
Still doing a “popping” when I’m in the “All out” tune. That needs to be fixed.
