I see. Well when I do a custom turbo set up the cab will be off again and I guess Ill debate on the cam sitation then. There are plenty of people making Big power on a stock cam, more power then I doubt Ill ever have. Next time Ill definetely do springs and pushrods since there are springs available that dont require machining so I dont have to pull the heads. Here is whats going on while the cabs off, if anyone has anymore suggestions on modifications or reliability factors feel free to post:
arp studs
oem gaskets
custom 4" dp
50mm waste gate plumed into dp
custom CAC pipe
custom intake elbow
ported rails from rudys
water pump is going to be opened up just to check it for cavitation (truck has 96xxx miles)
I dont have a lift pump, and plan on doing a custom set up with a few walbro pumps, a 5 gal. fuel cell, fuel bowl delete, and fuel cooler deleted and one put on the frame in the near future to finish off the low pressure system. So hopefully fuel rail pressure will be ok for the time being with ported rails.
