- Joined
- May 22, 2011
- Messages
- 15,240
- Reaction score
- 1
my truck drove awesome with a stage 1 cam ... curve was flat as a board, and much further out in the rpm range.
Which method did they use to install your cam? I assume the dropped the crank?
I run the same cam. Not sure if you saw the graphs posted, but my hp curve is flat and long. Don't know if it is a result of the cam, but I am sure it helped along with the other thingies.
Yes the engine can stay in. Trans needs to come out or at least be lowered done. Pull the flex plate. Pull the rear cover. Pull the rear crank flange. Pull the retainer for the cam and remove the cam. I bet if cabs up it will add another 8hrs of work maybe more. You'll need a dial indicator and mag base. Also the rear bolts need to be replaced, as far as I know they are the same as te front pulley bolts, the flex plate bolts are changed too. It's not a couple hour job to do this, setting everything back up takes time. Also checking clearences is slow and. Reds to be do e with care and precision.
Thanks.... Just ordered one. I'm assuming its the workshop green 2 volume manual?
