Well I was able to put a couple 100kms on it this week without any problems, truck was running amazing... Until today... It's a holiday for us today so I was heading to the gym early, truck was running perfect then all the sudden it started missing, lost power and was smoking white like crazy, I got it stopped and shut off quick. Won't restart now bit will crank over and smoke white out the tail pipe good, fluid levels all show fine, hasn't gained any oil... I need a better scan tool so I'm gonna look into that today (any suggestions is appreciated).. No codes.. Lp pump is fine and constant and 9psi at the regulator... For the moment I've ruled out Piston failure, it didn't blow oil anywhere and on the likewire it's asking for 35kpa and it's only showing 5...so I'm thinking an injector is hung wide open based on the amount of white smoke... My thought is just buy a set of injectors since their original and see? Any suggestions is appreciated as always
Sent from my HTC One_M8 using Tapatalk
