Jbenso127
dumb question, but what are ih pistons
I was wondering the same :doh:
So, for someone like me who is planning on doing studs and upgrading the valvetrain should I bite the bullet and go ahead and put in IH pistons at the same time. I don't have any huge plans for the truck like fuel, nozzles....maybe some bling from No Limit.
I disagree... i think the piston design just flat sucks...
Wouldn't you agree that the amount of piston failures compared to the amount of trucks that don't have issues points to it being a very limited issue? I don't think it's tuning related because base tuning is pretty much the same all the way around. It just seems to be more of a freak type issue than anything. Isn't piston failure among commonrails pretty common (Duramax, Cummins, newer PSD's)?
glad it back together bud. I'm working on mine now. red trucks cracking pistons unite!
Sent looking at my blown up 6.4
Well based on the picture it looks like it was spraying a little outside the bowl
Just cuz if I'm paying for dual fuelers I want to POWAAA. 30s arent out of the pixture though lol. RED 6.4s, piston cracking beasts 4 life haha
So you only need the IH pistons if the truck is red, gotchya!LOL
Pretty sure there was an injector failure. Bad injector could have possibly caused that.
I have seen several cracked pistons on here with a bad spray pattern which suggests probably a leaky injector (especially if the other pistons don't have the odd spray patterns). I figure that design of the stock pistons also doesn't help. Maybe since IH pistons seem to be better, they would be able to take more abuse from a leaky injector longer so hopefully you would be having symptoms of the injector issue before the piston cracked. Short of reading the temps in each cylinder, is there any way to prevent the next failure?
