uke: this kind of crap, spreading false information is rediculous.
H-11 failure=INSTALLER ERROR 99% of the time. the other 1% is nitrous explosions, etc. by doing something else well beyond their intended purpose. It's been proven time, and time again that H-11 studs are stronger than ARP.
Aside from needing to start with a properly machined head to block surface, in the seasoning process of the studs, all studs must be tightened to the first level using the factory torque sequence, then individually loosened, and re-tightened in that sequence until the seasoning steps have taken place. Once seasoning is done, then continue to follow torque sequence taking the studs level by level to the final torque spec.
If while torquing the studs, you loosen all of them at the same time between sequences of re-tightening, you might as well give your tools to someone who can use them properly, and get a job selling fries at McDonald's after you apologize to the owner of the vehicle for wasting their gaskets.
