On the other hand, think of a garden hose. If you turn it on and let it flow freely it puts out x amount at say y psi because its flowing pretty freely. If you put your thumb over the end of it the volume (x) goes down and the pressure
![Thumbs up (y) (y)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
goes up.
That is the similar example that I use, the hose, but I use it to fill a bucket. You have to understand your example when fully thought out in the proper way only goes to support Joe even more.
Once you get this point then it will all make sense. In your example the heads are your thumb. The turbos are not the restriction they are the pump. Until you do something to change the heads and cylinder flow, the restriction does not change. Maybe a ported intake takes away some of the restrictions but the heads are still your thumb. It is exciting to see what those heads will do on Rudy's truck.
Back to your hose example, so you have this hose filling this bucket with your thumb on it. How can you get more water to pass this restriction? Increase the pressure and shove it threw faster. If you don't increase pressure there will be no increase in flow past your thumb. It doesn't matter if you have a 500 gal/min pump or a 2 gal/min pump, if they both build the same pressure the same amount of water is flowing.
