extreme3807
The dyno was wayyyy low. 850 HP trucks were only putting down 500 HP. Definitely not an accurate number
talked to a guy on here with 205's and a 66 and he did 668 on fuel (with some water) and 8XX with a .092 jet. it was a mustang dyno but still should be mid 600's. contemplating that setup later this summer.....
new guy....mgeistman. i'm sure he'll chime in.
i talked to him on the nation....only difference in his set up and mine is the housing size...and lift& tire size....its a real strong set up!
I got on the dyno this weekend at the TS show and was kinda dissappointed I only put down 410 with 225/100's and a 66/77/.90 with erics X race tune.
I'm seriously looking into a single 66 with manifolds and divided uppipes. If it's still responsive on the street it's looking like a real viable option instead of compounds! stoked!
Are you looking to keep the 190s too or bump em up a little??
Ill let you know how a 66/73/91 with Matts (aka yours) divided up pipes and 205/150's drives on the street and towing when I get it together.
they actually flow 200 but I'd like to get them punched out some more.
that's pretty much exactly what I would end up running too (maybe a 71 turbine). toss up between that, trying vgt compounds, or non vgt compounds.
the new clipped 73 wheel spools like the 71 but flows more like a 74. Go big r go home!
why a 71?
