jdgleason
If you have 3.73 gears 3rd low will be way to slow. 1 high ftw. You can only run 3rd low if you have 3.55 gears and be competitive. Most of the trucks I setup that have a 5r I go with 4.10 and run 1st high. That makes for 12.7 final reduction. And the 3.73 is 11.5 final. 3rd low and 3.55 is 14.9 final. 11.5 is pretty steep unless you have big hp. I would reccomend smaller tires like 32-33" for the 11.5 final.
And I reccomend the dual shocks unless you want to spend more money. Just a hint, you still need to have good shocks even with the 4-link because they will still hop. It's all in the shocks, the radius arms work fine. I'm using stock radius arms on my 2.6 fully built pulling truck.
Depending on tire size, my truck with 3.73's pulls much better in 3rd and low.... the converter won't lock in first, and torque multiplication is better in third.
