Hows everyone pulling these truck?
89xj
Milton ontario
I'll trade dual shock pic for a lock up wiring diagram lol.
This is passenger side. I took my sway bar off. Used bolts through the swaybar mount on the axle for the shock bottom. I welded a nut into a hole thats already in the frame so I could just bolt the upper bracket I made to it. Takes about 8 minutes to install both sides.
kyle43335
Didn't you get the wiring diagram i sent you in pm?
Mike@MPD
Pasadena,MD
Ill see if i can get you guys a wiring schematic, i know it locks up instantly, i have not really tried it more than that, the first time i did it the truck wheel hopped and blew the planetary gear apart lol, havent been able to drive the truck since due to pcm issues but when i get the thing running again ill get a video just to make 100% sure it works right.
powerstroked08
Pennsylvania
Did this cure your hopping?
powerstroked08
Pennsylvania
The biggest two I've. Had them in are 325/55/20" and 35/12.5/18" I usually end up with about 1" of clearance.
Perfect! I want to get a set of 35/12.5/20"s this summer and didn't want to have to lose any of my turning radius with another shock. Thats good news.
100% cured the hop.
Great you and sledpull have me convinced! I'll be doing a double shock install this summer!:toast: Thanks a lot for the info guys!
nickg3130
West Long Branch, NJ
here you go.
use a 22k resistor instead of a 12k. i effed up when i made this
Awesome. Thanks a ton! I just have a few questions. 1) does the trans seem to shift ok under normal driving conditions with the switch off? And 2) do you need to have a 3 way switch or can one of the up fitter switches work? Sorry I'm just a bit of a newb when it comes to wiring especially when it's tapping into factory harnesses lol thanks
kyle43335
trans shifts perfect. off on the switch is no converter lockup. yes you need a 3 way switch, so you can add and subtract the converter whenever you like.
(aka) no you can't use a upfitter switch to do that schematic.
nickg3130
Oh ok thanks for clearing that up. So the off switch won't have the converter lock up at all? Then what position would be normal driving?
