LovinPSDs
yeah buddy! It'll happen... better track, better 60ft...if that doesn't get it there hit the diet plan.. and if not SPRAY!!!!
Ya Morgan I agree. Like I said before it's hard not to get stuck on the numbers but we are going to dyno in the next couple weeks so we'll see how that comes out. We still need to set up the wastegate a little better. It might be opening a little early and I could be alosing a little power from that. I also want to run the truck in Seattle at sea level and when it's cooler than 100 degrees at the track. I think we could shave off .03 seconds and get to that 11 second mark I wanted to hit. If we can do that then the calculator on this forum shows we'd be over 800 at the wheels. I think that's do able and I live at sea level so it would be a better test than running it at higher elevation and higher temps than I see where I live. Honestly I just want to be able to say I have an 11 second truck. The hell with the numbers. Hopefully we'll hit that mark later this year. If not maybe for Christmas I'll get a nitrous kit. One way or another I'm getting this truck into the 11s damn it.![]()
I think I need to find a happy place for my boosted launches at the drag strip. First run was at 15 psi. 60ft was 1.819 and 12.53 in the 1/4. No tire slip at all. second run was 20 psi launch just a slight chirp of the tires. 60ft was 1.753 and 12.46 1/4. Last run was a 28 to 30 psi launch. Some tire slip. 60ft was as you can see 1.828 but fastest 1/4 time of 12.38.
I had my tires which are BF Goodrich all terrains at 30 psi. I'll try 25 psi next time for the tire pressure. I'm guessing 20 psi launches is probably where I need to be I'm guessing from my previous 60ft times.
My reaction times were OK as I was leaving on the 3rd yellow light.
Any advice is always welcome.
We went to Dynomite Diesel's dyno event. Truck made 719 on first run with water/ meth off. It made 782 on second run with water/ meth on. It's loved the meth. Not sure why people think 6.4s don't respond to water/ meth but I have a dyno sheet that says other wise. I still want more so I think it's gonna get sprayed before we go to the even next year. Took 3rd in the twins class. Tons of Dodges, a few Chevys and only 3 Fords there. Every one was shocked when the truck laid down respectable numbers. I guess no one around here thinks a Ford can get it done.
I wonder what the deal is with your numbers being a little lower than some of the other guys with those chargers and 30% nozzles. I know I read Jared had two different trucks dyno 811 with that setup but you have A LOT of extra work done and are making less power....? That's strange. Maybe bump up to 60%?
