dmkolb
- Joined
- Sep 14, 2013
- Messages
- 100
- Reaction score
- 0
Those are some heavy rollers. I think the 248C has 4800 lb rollers and has been deemed a pretty accurate dyno over the years when comparing dyno numbers to track times.
As far as methanol goes, I've heard that it causes valve stem wear.
I asked the owner about the dyno while there and he said 7500 lbs rollers. I'm guessing he's right. Lots of guys at the event said his is probably as close to legit numbers as you can get. Several other places are all over the place with numbers but most who dyno often for testing and what not prefer this one.
There is no loading on this dyno. They of course can bring the rollers to a stop with a brake but it's not used for loading the dyno.
As for the valve stem wear I guess time will tell. I also don't spray all the time as Snow suggested for better MPG. I don't have it even start spraying until 30 psi and it's at full spray at 40 psi. I see boost max around 57 psi. So in a day it may spray once for just a few seconds but I'm not beating on it every day either so some days it doesn't spray at all. I just use it to help keep the EGTs down when there is heavy throttle and on wide open pulls as a power adder.
