Josh@DirtyDiesels
300/150's. IIRC Craig said they flowed 301cc
What hpop are you running now ?
Sent from on the commode with Tapatalk 2
stock. No options for upgraded 05 pumps...
Unless you put 04 rails and hpop system on it. Didn't warren diesel make a dual pump kit
Warren is a no no with Joshy
Why not give hybrids a shot and if that doesn't work dual pumps.. Past that you're ***ked without a CR lol
Okay nm then lol
Sure, you want to buy a set of hybrids for me? I don't have that kind of money laying around...
Josh I'm holding full ICP on 100% nozzles, whether or not your pump is as "strong" as mine may be a factor also because yours has more miles on it so it may be weaker. I want to run mine asap to see where I'm at as well. Might be able to give you some insight as to where your at. I know our setup is a little off (tire size, stock trans vs built trans, you now with a bigger turbo) but it may help? I'll let you know for sure when I run it
You should downsize your injectors big time. Hell 225/100 and your turbo would make more power than your current setup to be honest and have less issues with icp.
It's pretty obvious you're dropping ICP big time towards the end of the run. Have you checked to see how bad it is?
300/150's sound cool but if its not running right then what's the point nomsayin? A properly matched setup will always run better than huge ass injectors IMO
