I'm saying that is should have been stated that the injectors and cam in the motor are intended for a nitrous application and that it wouldn't be a fair comparison without nitrous to judge spool up. Just like you would have if it was a elite kit.
this motor was not intended for N20, it is Tadd's daily driver that was available for turbo testing, bigger nozzles with a lower tune will deliver as much fuel as smaller nozzles with a bigger tune......
the turbo will spool but you cant really do much with the truck since it makes 3lbs of boost cruzing even with 4.56 gears, in a comp only app the turbo would do fine even at our elevation but isnt very idea for street/city driving.
when they say that the turbo didnt spool that well they are comparing to every other setup, vgt, other sized turbos on different trucks, etc. as i said above its all about what application the turbo is used for.
