Jeff@Spartan
LOL
I'm saying that is should have been stated that the injectors and cam in the motor are intended for a nitrous application and that it wouldn't be a fair comparison without nitrous to judge spool up. Just like you would have if it was a elite kit.
this motor was not intended for N20, it is Tadd's daily driver that was available for turbo testing, bigger nozzles with a lower tune will deliver as much fuel as smaller nozzles with a bigger tune......
the turbo will spool but you cant really do much with the truck since it makes 3lbs of boost cruzing even with 4.56 gears, in a comp only app the turbo would do fine even at our elevation but isnt very idea for street/city driving.
when they say that the turbo didnt spool that well they are comparing to every other setup, vgt, other sized turbos on different trucks, etc. as i said above its all about what application the turbo is used for.
So its his daily driver and wasn't built for nitrous. So you thought it was a good idea to use 250s for daily diving. Hmm. Ok. But it was just stated above that it was intended for nitrous that's why it has 250s. Hmmm. You detuned it. No you switched to extreme street which only changes pulse width which is by no means the only way to control fuel. What about the spray rate. Or the fact that the pattern will get sloppy on huge injectors and won't combust properly.
Look if you built it for a daily then it was thought out wrong. If you built it for nitrous use then don't complain about driveablility. If you want to see how well craigs setup spools at elevation then use the same fuel set up he claims works so well and compare it.
Do you live in Roswell? Holy ***. The truck didn't work at elevation. Its not a conspiracy theory. Its fact. Craig's works at sea level and works well as seen by yesterdays track times. This has been an ongoing topic of question for sometime and the results are finally in to lay this one to rest. Lay off, or strip your truck down, drive to Pueblo and report back. Jeez
Ok now you're really startin to shine as a dude who doesn't know his ass from his elbow. Do you know what the difference between 1.75 and 2.3 pulse width is? Cuz it's friggin huge. Let's forget all about the 475. Why don't you think 250s would work for daily driving? In your infinite knowledge and experience, please enlighten us.
Why don't we look at duramaxes for example. Duramaxes dd WAY bigger nozzles than that all the time. Have for years as a matter of fact. It's all about tuning and airflow, correct? Correct. So, who are you to say it was setup incorrectly? Since obviously you must know what the future plans for this truck are, do you care to share with us? Any idea what kinda cfm that truck will see?
<------- lets pretend this arrow is pointing to a box. You go ahead and keep thinking inside of that box and the rest of us will be over here ----->
I'm done. It was a fair comparison with similar fuel and tuning. It just won't work.
Personally I don't see how 250's are streetable unless it will be on something with triples.
I would put 250s in my truck and I bet it would drive fine
At a lower pw right?
Yea definatly
Would the reasoning for running them at a low pw so you could spray for the track or the dyno by changing the tune?
