Jeremy @ No Limit
A little afraid to get to crazy with it until I get some traction bars.
Give us a call when you are ready for them!
I dont have spar10....h&s... but im right around your temps. Driving home at 85 to 90 i see 206 to 210What engine oil temps are you guys seeing on Warhammer? I've seen up to 205 when it's 95* outside cruising. Stock I was around 185*-190* from what I remember.
Hey Spartun. I continually get the p2074 code these days. Anybody know why. The only thing I can think of is we've gone into extreme humidity and temperature fluctuations.
This is on the Warhammer tune with a NL stage 2 intake.
anyone else getting a trans squeal on the 4-5 shift?
Depends what kind of squeal. My squeal was my transmission slipping.The squeal just happens in some of the trans. I have been told it doesn't hurt anything it's just annoying. Sometimes they happen even in stock trucks. Just make sure you tranny has relearned completely. It took mine quite a while when I first installed ******* tunes
How many miles have you put on it? Some are getting the squeal once or twice at first and then it doesn't happen anymore.
Every once in a while I have a weird 3/4 shift. Seems like a little transmission slip - rpm's rev up about 200-300 as it shifts into 4th. I've noticed it when driving easy. This is on 500 level haven't messed with higher.
Just wondering if this is happening when the truck is cold or after the tranny is up to temp?
