superduty prerunner project
backwoodsboy
Merica
I don't know then man...half just throwing things out there and half curious.
So with the Carli kit the front spring hanger is moved forward from stock to accommodate the longer leaf pack, and the rear remains in the same location? Or are both spring hangers moved?
I'd be really curious to see footage from a go-pro or something similar mounted under the truck watching articulation during a high speed run as well as torquing the axle with the brakes set. Should give a pretty good idea if axle wrap is your issue.
SSpeeDEMONSS
6mi from the beach, SoCal
I had a truck with similar issues after swapping leafs in the rear.
Static ride height the axle was completely centered. Under bump the axle would shift forward.
After a whole lot of screwing around we decided that the shackle length was too long. Basically the longer shackle was increasing pinion angle right off the bat and having the shackle at the rear was causing the axle center-line to shift forward under bump. Both were contributing to bind in the drive-train.
I'm sure I'm over thinking things, and you've just got a little bit of axle wrap going on, but that's how my brain work.
Did you do anything to the shackles when installing the Deavers?
Were the springs going into a negative arch during bump?
Garrett
probably getting paid at work to post this from my POS phone
SSpeeDEMONSS
Are the rear shocks valved for those springs and your weight? Put the gopro under the truck pointing towards the axle and spring and drive it. See what is happening, not from a valving standpoint but to see how much axle wrap there is when loading and unloading over bumps.
Garrett
Cutting-Edge Diesel
Newkirk, OK
I was wondering about that. I need to get a gauge so I can check them anyway.
Soooo I guess I lost my gopro case out the back of my truck so I'm going to have to get a case before I can film it :doh:
Twinturbostroker
El Paso, Tx
Haha yeah 200psi is a little higher than anything I have goes
Yea, but its not at simple as just putting the gauge to it. There is so little volume in the shocks that checking the pressure like you would with a tire gauge will change the pressure substantially. Fox gauge runs about $65 and works pretty well, but you will still lose a great deal of pressure just checking them. It's best to have a nitrogen bottle with inert gas regulator to check them......
Cutting-Edge Diesel
Newkirk, OK
soooo I had to pull a calf in a pasture and all of our ranch trucks were in use or had a flat tire. So I took the pre runner out in the pasture. Well when I got there she had decided to relocate and we had to look for her (640 acres) in uneven hilly ground with alot of rocks all over. anyway on the way back home the thing rode better than it has been. kinda what it was like a few weeks ago. Not sure if shock temp plays a role in it?
