thats not good.......
Are these gates failing because of the heat generated where they are located?
Maybe the water cooled Tial gate that Dustin posted is the answer.
http://powerstrokearmy.com/forums/showthread.php?t=2941
After hearing about Eriks and Mikes(if the gate caused it) I am concerned that this may become an ongoing issue.
With the heat generated from daily driving I am starting to think the gates internals are going bad causing the gate to fail, which then takes a turbo out.
Haller.....any results from the truck you installed one on?
I think I am going to go ahead and have Aaron switch mine over to the Tial and run water. I dont think Im going to be happy if I have to pull the cab again for this problem.
Erik/Mike are you guys going to do anything different than before in regards to the Precision gate?
Discuss......
