Erikclaw
Was the final turbo setup an 88?
Yes it is an off the self 88
Is doing a remote mounted atmo better or worse or no differant than putting it on top? I'm just curious as I have no clue.
It's amazing how well turbo set ups work with a very large turbine on the low pressure. Pretty much put 150 hp on JD with almost the same compressor sides. Been saying this forever lol. Happy for you Erik that's awesome. Headed down in a bit to go check it out. When you coming to get it?
If Eric put 150 on jd with 38s or whatever is on it jd def has a problem
.... Except my turbine and Mal's are withing 1mm of each other and Mal's truck made the same power with less fuel. Same with Shone's...
My truck has an issue lol
Just buy the same 88 as Erik and convert yours to remote mount jd. I think you'd like it
But you have more mass air flow from a larger atmo but less turbine. And high back pressure to go with it. Back pressure is like having an exhaust brake on
Turbine restriction my friend
