SEABEE08FX4
I never understood why people do that, I get people calling all the time trying to do that.
Just an update guys. Matt is pretty much done with the tuning...but he could only go so far. The turbo will only make 26 psi. RCD street file would only make 26 psi for me as well.
With the live tuning, normal driving and runs to half throttle are smoke free. He can jack the backpressure way up and get it to make 30 psi but thats it. EGTs are still toasty. No chance of towing.
He says the way it is now, the truck is running clean and a blast to drive....but turbo wont build boost. Says it makes good power....but is being held back.
I'm hoping to get the batmowheel off of it and see what it does if I can get my hands on a cast wheel. Lance (stroke of luck) has the same turbo but without the batmowheel and has no issues...
Thats crazy, I wonder why it won't build any boost. Your running 190/100's or 190/75's ?
No exhaust leaks ? No boost leaks ? That turbo seems to run well on other trucks such as Lances. Not knocking the injector builder but maybe it has a bad one, mistakes happen. Has there been any data logging or a balance test done ?
Exactly, Jake Kelly's truck rips with 205s and the 68....Yours shouldnt be overfuled - atleast not to the extent that it sounds..
Jake is running a cast wheel too right?
Yes - if that does solve this then great.
easy....Hoffdizzle loves them now![]()
Same dude that rep'd the turbonetics charger on his whip.
Honestly the ported manifold may show a decrease in overal boost because of less restriction, as long as it translates to more power to the ground.
