Jmoore1225
- Joined
- Dec 30, 2011
- Messages
- 334
- Reaction score
- 0
Why is it the #8 is so prone to cracking? What is the best add on's to help prevent it from happening?
Sounds like a piston went. Mine through the same code. When I opened the hood to see what it was going to be like to do the injector, the whole underside of hood was covered in oil. Loosened the oil fill and it blew off. Ended up having to have that cylinder sleeved. Coincidence or not mine was also number 8 cylinder. If you do have to tear into it, I highly recomend ceramic coating the pistons. Well worth the money. I only replaced that one and had the others checked
