BFT
Probably had a crack and went from there
I think I'm just gonna put the one piston in it if it's only one. I mean if it's like Jeff says, I planned on doings 30s wouldn't it happen again do to lack of air?
I broke 3 out of 4 on pass side. I think it was a combo of poor manifold flow and crappy intake elbow. Iirc the pass side is odd cylinders and the rear was broke with a hole in it, then moving forward each piston was cracked less and less. The fact it happened all on one side tells me the elbow can be a problem.
Even with the upgraded manifolds and uppipes singles have it won't help move more air? I'm just thinking since I'm gonna have the motor out of it if need be I wanna build it how I want. But def not have it out twice
More fuel = more cracked pistons.
