SEABEE08FX4
I got a new one. Not cheap. Was unaware they had a cat in it. :doh: If I could afford the down time I'd do away with it.
:edit If I welded it up it would most likely crack again. Hard to see in the pic but it was almost broken in 2.
Drill and tap the blocker plate to accept the back pressure sensor that's in that egr pipe, then move the blocker plate to the port where the egr pipe ties into the up pipe.
