Well.... I was bored of my setup!!!!
Swsignal5
Than build yourself a turbo Walt. I would be more proud of a functioning combo, I'm sorry but these I am enginer check out my broken motor is a joke.
Your a joke. All I see from you is pointless comments about nothing that has to do with you, and get it right. My combo worked great and was in great running condition when I pulled it out. I've never seen any info from you on any post that actually provides useful info. I'm sorry that your incompetence brings you down but you don't need to drag everyone else down.
By the way. How does everyone on the forum know if setups work? Oh yea by TRIAL AND ERROR JACKA** BY PEOPLE SPENDING TIME AND MONEY TO GET ANSWERS FOR EVERYONES BENEFIT!!! So quit acting like your a rocket scientist!
And also since your so smart, it's "engineer" and a "motor" is electric. I work on my "ENGINE"
ChattyCathy
It's yore.
97stoker350
south central pa
Here come the inside jokes and pointless comments to cover up the fact that he actually doesn't have anything remotely intelligent to say.
Btw was not directed at mike
4EverBoosted1
This guy never has anything productive to post^ OP check out 4everboosted1's thread he used a 62 and 75 I think and he made over 900
62.5mm and 80mm, 921hp. Great setup, we are so happy with how it performs.
Athens, IL
Yeah I heard of a couple locking up on the crank from them being so big. But it could be just talk.
That's not an R&R problem.
I've heard of that on 6.4s where they have to machine a little bit of the block for them to fit but not on the 6.7s haha guess I'll find out!
Carillo's are the ones that hit the block because the bearing end is too big.
No too close to each other on the crank. Once they start to get warm and the metal expanded they stuck together and seized the motor.
There was a different issue with that than the rods. But I'm not going to get into it. If your think it was a rod that locked up on start up then go ahead and believe it.
It's not the rod's fault if the builder doesn't check rod side clearance. I'd be willing to bet they didn't check bearing clearances either. A true motor builder checks those things, and many many more. A parts changer simply bolts everything together and hopes it lasts long enough to get paid.
Yep, but don't worry.... Let's blame the rods. Lol.
bigrpowr
<How I Fly
Administrator
well my R&R's did not lock up, and my balanced engine is SO smooth. thanks r&r , and morgan for supplying them !
