Super08Duty
Preciate it Ryan
Intakehoses.com has all your solutions for any intake you need
You guys dont plan on running any nhrda events i quess?
batteries have to be in factory location unless you want to run pro-street
NHRDA Super-Street S/S
» Heads-Up class with a 4/10ths Pro Tree, Pro Ladder by ET, Auto Start on
» 2wd Minimum weight: 5000 lbs (w/ Driver) ±1%, slick tires permitted
» 4wd Minimum weight: 6000 lbs (w/ Driver) ±1%, DOT approved tires required
» Tube chassis, back halved, 4-link, 3-link style rear suspension prohibited
(Note: Traction/Ladder Bars allowed)
» Hood/Fender Stacks prohibited
» All Exhaust must exit up and away from vehicle
» Must have OEM Style transmission (Note: Lenco, Liberty, Bruno, Clutchflite, Danco,
or similar prohibited)
» Engine must be forward of OEM Firewall
» Must meet NHRA and/or IHRA tech and safety requirements for MPH and ET
» Must meet NHRA and/or IHRA licensing requirements for MPH and ET
--- Rule Revision Effective February 1st, 2012 ---
» Fuel cells are permitted and do not have to be mounted in stock location
(Fuel cells must be SFI approved)
» Battery(s) are no longer required to be forward of OEM Firewall
