Drop in batmowheels for stock 6.4 turbos
Dustball8504
Everett, PA
Just left fall brawl, dynoed 510rwhp and 1019rwtq on IDP XRace with a 1 percent correction factor. Everyone said the dyno was reading low. I'll hopefully get the batmowheel installed next weekend and dyno the following week. Stay tuned :D
WoodBoy
Alabama
Dang i would say so also
you going to put it back on the same dyno after the swap? That will be the only accurate way to test it
That number sounds kinda low honestly
BUT my truck has never dyno'd well with erics tunes for whatever reason
BEST thing to do would be hit the track before and after as well, that way you have two baselines
Dustball8504
Everett, PA
The dyno used for fall brawl is the closest one for me so I'll be going back to it. I haven't gotten a pass in at the track with the xrace yet but I can go run it again with my gearhead tune that ran 13.3.
TheBigDeOGE
i didnt take time to read the whole thread yet but i'm running a bat mo wheel in my tow rig. it was a hx35 and i had the backing plate machine for a hx40 wheel and got a 40 housing and saw 200 degree drop on pyro ( granted i put BD manifold on at the same time but also added hotrod vp44 so that should make it run hotter but it didnt)
Smarty on level 8, edge on 3 and hot rod....low low low smoke. she needs more fuel now. bat mo wheel definitely moves some air. its instant spool now. (yall pretty well have that now anyway)
O2ShootTheJ
^^^ LOL
pending the results, any chance you could do a write up on this so some of us less knowledgeable guys could do it ourselves?
onebadf150
New Orleans
Thanks for the pics Dustin! Is the batmowheel something you can install easily or does the turbo have to be sent to mpd?
