Annnnd BOOM goes the dynomite
OSCS
Houston, TX
The inconsistencies at easily explained in his posts by the fact he was answering a question I posted. I was asking around about getting a motor built. I was quoted 6300. The heads were beefed up and ported but when I went through the list of parts with the shops owner, his list was calling for treated forged rods. We know this is not.sufficient for a build that adds power, especially for somebody that is anticipating compounds. Sorry for the confusion!
Needless to.say, I'm not considering that shop for a build. Nobody around where I live wants to touch anything on a diesel.
thank you for clearing that up
OSCS
Houston, TX
Ok so I'm going to go with a forged internal short block rebuild. Is there anything I should tell the builder to do while it's under the knife.
Big Bore
9000ft in the CO Rockies
Is that block getting sleeved? If not, you should really talk to Lott about that. In fact, doesn't Lott still sell a forged short block? His are sleeved if I remember correctly.
OSCS
Houston, TX
No it's just a bored over rebuild. Lotts rebuilds are 3500 and I'm not sure on the sleeves. It doesn't mention sleeves on his website
Big Bore
Lotts rebuilds are to a different spec than the normal rebuilds from his supplier, and one of those specs is sleeves (which would account for the cost), because there is no way to tell if the sleeves are corroded away on the inside of the jacket, and I believe he had issues with that and a couple other things in the past. Just something to consider, because after talking to David, sleeving is the very first thing I would have done to a block, second would be all new fasteners. If I wasn't going to have the sleeving done, I would look for a stock forged long block somewhere. I really encourage you to talk to David about his block, as all the details are not in the ad, then compare to your other option.
farm boy
Rosharon, TX
Get whoever David uses to port the heads. I wish I would have had the coin to get it done while he had my truck... :fustrate:
OSCS
Houston, TX
Just talked to my rebuild guy.. He says they don't have sleeves. Hmmmm and they reuse factory fasteners on the bottom end only replacing new ones on the heads
Big Bore
I'm not even sure David uses new fasteners, just something I picked up somewhere while researching my build, but I would not be surprised if he did, or could add them onto the deal.
IMO spending the money on a new block, without doing sleeves, is just taking a big gamble.
OSCS
Houston, TX
This guy is saying they don't have sleeves??
OSCS
Houston, TX
I don't know, I've never broken down a 7.3l block so I couldn't say wether it does or doesn't. I'm simply asking for advice or suggestions on what if anything I should have done to the short block while it's being rebuilt.
Big Bore
Have you spoken with David yet? I highly recommend it.
521turbo
MICHIGAN
Big Bore
Are they boreing the block out then adding steel sleeves. Because 7.3 dont come with sleeves. They are just a cast block no wet or dry sleeves.
Big Bore
If the 7.3 did not come sleeved, then I'm sure it would require boring. I never really looked at that aspect of the block the couple times I've had one apart. I know that David told me he has it done, and his reasons, which I agreed with. It changes the integrity of the cylinder walls from an unknown quantity to a known quantity. Without sleeves, I just don't see how you could be confident that you have a "new" condition block. This is particularly important with our motors which are sensitive to cavitation in the coolant and pin holing.
Gearhead
The factory block is not a wet sleeve design. A small overbore won't hurt a thing.
ToMang07
Mainah!
I would think ^THIS would be the most important reason to do it!
