Gfulton's Build
Breaking Habits
Mapleton, Illinois
Morgan, I always replace the track rod joint with the upgraded one Dave makes and it completely kills death wobble. It's amazing how much it plays a part in it, at least from my experience. Fwiw, I have 3 trucks running ala's with the joints flawlessly
Athens, IL
We just did an OUO track rod joint, ala's and traction bars on 50shooter's truck. It had the same death wobble.... Completely cured it and not only that it seems the ride and drive WAY better than stock.
MorganY
college station, tx
Glad I have the exact same setup on mine!
It has the icon adjustable on it right now, still need to move to the OUO unit?
What about dual stabilizers, do you all have those as well?
Breaking Habits
Mapleton, Illinois
WHY NOT
Carlyle IL
When I put the ALA's on my truck I had them adjusted and aligned the first time to about 5.5* of caster and I didn't care for how it drove. Seemed to be all over the road and dart with any little movement of the wheel. I had the truck realigned and I am actually running less caster than stock at the moment. I think in the area of 1* and it doesn't drive bad. Best part about ALA's is they are adjustable set them how you like how the truck drives. I plan on adding caster a little at a time and seeing how the truck drives each time to get it exactly where I like it.
jcain
After dozens of adjustments, I decided 3.2*caster was best for my set-up.
MorganY
college station, tx
Sorry I haven't updated the thread in awhile. I have been busy with a conference, and my full time job. Parts came in Thursday. Got everything straightened up (literally). The icon track rod adjusting sleeve was the issue. No matter how tight I got the sleeve, there was too much corrosion and slack in the threads to keep the rod from moving. Before I changed the entire rod, I ended up putting a 1" weld on the sleeve/track rod to verify the fix (which it did correct the problem). I figured it was worth a try, because I was still putting the new one on regardless.
https://youtu.be/Fn_mYVm95ns
Problem ^
Fixed
https://youtu.be/sxEyXEczOA0
As far as the castor adjustments, Gary's is just north of +4°. Anymore castor on his truck and the driveshaft will bind. I ended up playing with castor from 2° through 4.3°. 2, 2.5, and 3.3 felt more harsh than where it is at now.
