Spatel23
smoke in the video wasn't bad, but Im guessing its no indication of its street manners
You will be able to run the x race on the street when you get Erics new tunes with the trans shifting file
If your power is close to when it was with stock turbos now with only 38 psi wait til that turbo hits 48-52 psi
One thing I found out was injectors really wake the 6.4 up with turbo spool up
it helps alot if you clip the tow haul at around 40 mph than it will hold off overdrive im trying to get a custom trans file made it would make a big difference
