Craig@MFI
- Joined
- May 18, 2011
- Messages
- 2,184
- Reaction score
- 0
Just made 845 with the 75 on x street
Loaded the xrace today just to see what it would do. Pretty powerful, much stronger then the stock turbos and the x race. boost still only got to about 45psi. Not really a street tune in my opinion, very smokey and extremely touchy when it locks up. Also has about twice as much lag then the x street.
ouch....
What elevation are you at?
on the mid range tunes yes its streetable, just not for everyone. If you live in a large city, stick with stockers or go to tow powers. I personally dont like having a lot of smoke behind me while driving around town, especially when im passing someone right after lock up. The xstreet is about as high of a tune ill drive on the street. I think the New mild tune is probably perfect. I have a video of my go pro sitting in my bed facing the stack to show the smoke while driving around but my computer wont upload it. If i can get my buddy to load it for me ill post it up. One of these days ill hook up to a trailer and see how it tows, i just worry about going up a hill with a load doing 55 or so when i locks up.
Ill also be hitting the track saturday. Should have someone filming me make a couple passes.
Is craig running a really loose converter? Even then the problem is more when the converter locks.
Now you guys can see why I got rid of my single at 6000 feet.
What I think you should do is give mike @ kem a call and have him send you a non vgt 275 tune with the tow haul button acting like a overdrive off button... that made my truck alot better. And even now I wish I had a tune like that for certain times.
Sent from my DROIDX
Sent from my DROIDX
Do you have bigger injector or stock? I heard that injectors help a lot with spool up. What gears dose your truck have in it? My high gears ans big tires are what kinda scare me.. ithink im only at like 1750 at like 75...
You have to have a boost leak of some sort or exhaust leak because there is no way it should be that laggy
