question/tips/tricks/advice/how to thread
Ok. Thanks fellas!
Wish it monitored % wise on oil and def. Be a little more heads up instead of the way it does it now.
donniesd
Found out you can roll down the windows from the remote, but any wait to roll them back up?
LovetheTide
Fort Worth
Just picked up a new truck, 2012, without a manual. I have the sync system and want to hookup up my galaxy S4 to it but but the dealer (chevy), said I needed an attachment to do so. I've tried messing around with it but the truck is not able to find my phone when searching for bluetooth. Any info on how to get it setup?
12stroker
Corpus Christi, TX
donniesd
How do you do this?
Global Open Windows (If Equipped)
Note: The ignition must be off and the accessory delay feature must not
be activated in order for this feature to operate.
Note: This feature can be disabled or enabled by your authorized dealer or
through the information display. Refer to Information Displays chapter.
Press and hold the unlock button on the remote control to begin opening
the windows.
Press the lock or unlock button on the remote control to stop motion
BK39
Texas
the windows.
YOU ARE THE MAN!!!!!!!!! I've owned this truck for over a year now and never knew about this. Will come in handy during the Hot summers.
Strokin&Smokin
Louisiana
This may have been answered already but what happens when you pull out on the 4 wheel drive knob?
I was messing around with it and didn't know it pulled out.
I did a couple burnouts with it out and the only difference I can tell is the the back end starts to hop. It NEVER does this with just advanced trac off.
Sent from my iPhone 5s using Tapatalk
Its supposed to lock in the rear dif if it has an e-locker... it prolly wouldnt be doing a burn out if you have it... normally on mine it will still de fuel and cut out even when you have the advanced trac off... it automatically overrides it..
Strokin&Smokin
Louisiana
I tried it again and they turn over, the ass end hops for a second then it defuels even with advanced trac off.
Also noticed that while turning with it pulled out the ass end feels likes it jerking side to side. I'm guessing that means the rear is locked?
He said he pulled it out so that means it engaged the locker.
It will still pull out even if it's not equipped with the e locker.
If you're going over 20mph does the dash say to slow down to 20mph to engage locker?
