webb06 official build thread
webb06
Seneca, MO
Been raining ever Friday night since its been done. First Friday it's dry I'll have some times
webb06
Seneca, MO
Hitting the drags trip tomorrow. Any advice? Tire pressure needs to be at? Use the tow haul?
jdgleason
Fort Collins, CO
Tire pressure 25-30 in the rear 30-35 in the front. I would say leave around 15-16psi and see if it hooks... If so, keep upping that until you're happy/comfortable with your 60'.
No tow haul.
bigrpowr
<How I Fly
Administrator
i run 30 front 25 rear .. with street tires. just wait to see them bulge and you know you dumped enough.
webb06
Seneca, MO
Did a little checking under the good this morning. Have a small exhaust leak around the factory pyrometer. I replaced it when I had it torn down but it's leaking around it. On the hp turbo there seems to be an exhaust leak where the vgt actuator comes through the casting. Not sure if that's possible. Also have a small oil leak on the homemade oil drain for the low pressure 76. Dipstick still shows full but just enough to make a mess right under the turbo.
