webb06 official build thread
BFT
southern cali
Could be either the MAP or the EBP sensor. You're atbthebtrack so you won't notice it since you build boost off the line. If you have a DD to monitor and reads 0 or lower on boost then you might want to change the sensor
webb06
Seneca, MO
I'm not at the track now and it seems to drive fine. Mash the pedal and it takes off but throws the code
BFT
southern cali
I got the same code and it was the EBP sensor. Sounded throaty (similar to a single) on start up. Mine progressively got worse
webb06
Seneca, MO
12.6 @ 109 was my fastest tonight. Quite a disappointment really. I never got a decent launch at all and kept getting the p2263 code for turbo performance. I was trying to launch around 1700 rpm but I'm pretty sure it wasn't really building much boost to launch hard.
I thought I lost the converter but everything seems fine now.
No break downs but I think I'll go ahead and replace the EBP sensor
webb06
Seneca, MO
I guess I wasn't getting a good launch right? It didn't feel like the tires were spinning. Just felt like no boost then maybe 60' in everything lit and took off
bigrpowr
<How I Fly
Administrator
yeah , then you have to leave harder. keep increasing rpm at launch until it starts hopping and you know you've hit the limit. it should be low 1.60's , which would put you in the 12.2-3 range
webb06
Seneca, MO
So if I get some custom gearhead tunes on a spare livewire I've got I need to have the exhaust sensors plugged in or actually in the pipe?
NathannialD
Burlington, NC
just a thought, just because you are bringing up the rpms doesnt mean the atmo has had a chance to really get spinning. if it were me id have a gauge on it so you know that its making boost before you go to launch.
webb06
Seneca, MO
Ya I was kinda thinking that after leaving the track. You mean a gauge on the atmo itself? Or just watch the boost gauge on the dashdaq?
webb06
Seneca, MO
Well I guess I could hook up a manual gauge since there's a port on the front cover of the atmo.
