Deranged rebuild, the next chapter
ford rules
I can't believe it won't keep up with a 285 hybrid on a full PW. Isn't the pump supposed to be able to handle like a 280 conventional?
ford rules
Man that sucks, truck probably still has a lot left in it considering it's still way low on HPO
Cutting-Edge Diesel
Newkirk, OK
Cutting-Edge Diesel
Newkirk, OK
fixed the pinion brake that failed at the last race and pulled the trans to reseal the rear cover hoping that will solve our oil drip we have been having after a nitrous pass. I have a engine diaper coming anyway just to be safe.
planning on going to truck fest in Denver this Sunday to compete in their pro diesel class.
Twinturbostroker
El Paso, Tx
Get'r did :thumbup:
Cutting-Edge Diesel
Newkirk, OK
New flex plate must not be on all the way or something. It's rubbing the bell housing. Have to pull the trans back out and see what's up. FML days like today I really wish I had a 2 post lift lol
Mdub707
Mohawk NY
Matt did you ever figure out the low HPOP pressure? I know you said you were thinking of swapping the pump over to your other truck.
