BW S369?
Six_Sloww
Southeast MI
I would think also- I can also call htt if I worry to much lol
Well for the braced port they have to send you something because wtf are we supposed to do if we don't have plans for it.. As for the npt port you can go to any hardware store and get a plug for that lol.
TALLBOY
Ooooo duhh my bad.. Yeah your boost will max out and the factory ebp sensor isn't really accurate for what you need it to do.
I would get the expansion kit and get aftermarket sending units for the boost and bp
So I have all the starter and expansion kit edge parts can I use the psi sensor like my fuel sensor for the boost and one for the ebp? If so do I drill a new hole for the ebp. How do I mount it so don't melt it.
TALLBOY
Yeah I would say ones for a wastegate and the other is for a boost fitting. BW just makes these covers universal so its user friendly if you need it. As for the braced one I'd ask BW for sure.
Six_Sloww
Southeast MI
You'll need to make something like this
Copper tubing with compression fittings will work
jester2011
What are the lbs per min on the 72 mm atmos guys are using?
jester2011
So the spacer that elite makes wouldn't work for that? It would have to ?
Six_Sloww
Southeast MI
It would. So you buy the spacer, build custom piping, fabricate feed and drain lines, then adapt to your current intake just to make similar power to a drop in no hassle 72mm?
I suppose you can do that, probably cost 12-1500 more than just dropping a turbo in.
SEABEE08FX4
Montgomery TX
Too small to be an atmo
No its not, its bigger in every way than the factory one.
Yes you could, and you would have to use it and or make your own.
Power would be similar ( depending on who's wheel), back pressure would be better ( larger turbine, more turbine housing flow ) and spool up would probably be the same and or better.
Six_Sloww
Southeast MI
I guess my argument is if you're going to do that setup why not an s472, then gate into the atmo seems like it would be better hp per dollar.
That's not to say I wouldn't subscribe to a thread where someone tries the 369 as an atmo lol.
