After market HPOP
Crowerstroke02
Brandon,fl
* honey badger jr* from dyno proven will run 300/200 no problem. I have seen it first hand with 300/200's. I personally run 238's with honey badger jr and swear by that pump
V-Ref
9 miles high @ 550 mph
Crowerstroke02- do you have PW/DC/ICP #'s to share with the OP on your experiences with those 300/200s and the Badger Jr?
That overdrive is tempting vref...A t500 and that would be sweet.
PABowhunter
Are there any vendors that can get BTS duals? Or do you have to go directly through BTS? How much $ do they run?
emev0l
Lincoln locker adrenaline has like 65% DC with stage 2's
I've never ran one but everything I've heard were 65% if it can even hold 3,200 at all.
Whats letting his hold 3,200 at 20% ?
thuglike
Linden, NJ
I'm not knocking the honey badger jr . I think it's a good pump but I feel 300/200s would be too much for it.
We would never recommend the Jr. for those sized injectors. We have seen real good results from testing but for day in day out driving the 1 product on the market right now I would recommend.... Termy Duals
thuglike
Linden, NJ
Copy and paste post from an earlier thread:
Some notes from Jonathan........
300/200 P.I.S. injectors
Honey Badger Jr. pump
Jonathan tuning (PW was set to 3ms)
Calling for 3000 psi at wot..
Pump help 3000 psi at 55% dc
Truck did 588 on the dyno
Next.........
Upped the PW to 3.4ms
Called for 3000 psi at wot
Pump held 2850 psi at 58% dc
truck did 596
next...............
upped PW to 4ms
called for 3000psi at wot
pump went to 3000 psi then fell off the table to around 1800 (then again, every medium oil pump we tested did this)
__________________
MossBack
UTAH
Next.........
truck did 596
next...............
upped PW to 4ms
__________________
That is what i was thinking of... sorry for interrupting it as ok for daily use.
cjfarm11
Termy Twins. Thats my next move. Even with 250's i dont think the T-500 is enough.
2000wa250
Twins here, only downside is your low pressure pump better be in good shape because these babies need a lot of oil moved to them. My low pressure oil in the res drops to 12-15psi under any throttle with them so clearly my lpop is done.
bruce
Middle east
billet stealth FTW, it was a tough pill to swallow at the time but it seems to be an alright decision these days
Arisley
Arlington, Texas
Your Adrenaline can hold 3,200 PSI at 20% duty cycle with 250/200 single shots on a hot tune for 12 seconds?
I'm not saying it doesn't but I've never heard of one doing that well.
Just checked it this morning, starts at about 20%, quickly goes up to about 60%. By 12 seconds or so, it is only holding 2900 lbs.
That's impressive. Do you know the PW being called for on that tune?
Not sure on the PW. My scangauge only monitors two things at once.
emev0l
That sounds more like it, thanks for checking for us.
